Empusa
Hello!
First of all, i don't have much electronic knowledge, but here it goes.
I have a small stereo amplifier with two 3W/4ohm laptop speakers with usb source.
When my friend asked me to see what's wrong with it, it was completely dead, which proved to be the audio cable.
So i replaced the wires, but now one channel is buzzing increasingly louder with the volume. So if the volume is low, the buzzing speaker is kind of ok, but the more i increase the volume, the buzzing distorts the sound so badly that i can't even understand anything on that channel.
And the problem is definitely on the board since i swapped wires, speakers and anything i could to exclude other issues.
Then i started to measure the components, resistance values, voltages, they are identical on both lines and it's getting really annoying. I don't have a pump now to take out components and check them individually.
So at this stage i have only two options. Either i pull them all out from the buzzing side and measure them, either i couple the stereo signal into a mono one as i saw through a resistor bridge, which i am not sure yet of what values.
But i would really wish to fix it, regardless the fact that they are so cheap, i could sneeze and it would be more expensive.
https://imgur.com/GxUzfRf
and the two amplifiers name is: hxj8002
