Hi
I was looking for an analog isolator IC for some kind of 0..10V (for the driver) and I found a weird one on the internet called the HCNR200. this integrated has functionality that I haven't seen before. According to me, there is a different management system. I want it to be sensitive. There should definitely be a sensitivity of about 20mV. that's why I read the entire technical document this morning. Although there are sufficient explanations in the technical document, I still have a few questions in my mind that I cannot answer.
I plan to create the circuit diagram in figure 12.b of the technical document (page 11). According to this scheme, two external opamps and 2 external resistors are required. The circuit in the figure states that it is applicable in the technical document, but no mention is made of its sensitivity. I know the sensitivity is relative to resistors and opamp. So which opamp should I choose? I have vintage opamps like LM358 in my inventory, but I don't know if they are suitable for this job? If they are not eligible I cannot spend more money. So goodbye to the HCNR200![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
The same technical document also includes another circuit that provides precise analog isolation (Figure 17), but I don't really want to struggle that much for an isolation process, I think it's too complicated and too crowded. For this reason, I chose to establish a simpler circuit model that can provide 20mV sensitivity (Figure 12.b). The technical document states that C1 and C2 capacitors in figure 12.b are intended to increase stabilization, but it did not write at what values they should be selected. what should these values be?
And my most important question is; Do you think this integrated is suitable for this job? What are the integrations that can provide cheaper 0..10V isolation? What are the analog integrations you use? What do you think should I do?
Thank you.
Thank you.
