Analog to digital converter atmega 8
mah
what is worng with this code. ? it is working in proteus but doesn't respond in real chip. i use 8 Mhz crystal
C:
This program was created by the
CodeWizardAVR V3.12 Advanced
Automatic Program Generator
© Copyright 1998-2014 Pavel Haiduc, HP InfoTech s.r.l.
[URL]http://www.hpinfotech.com[/URL]
Project :
Version :
Date    : 30/01/2018
Author  :
Company :
Comments:
Chip type               : ATmega8
Program type            : Application
AVR Core Clock frequency: 8.000000 MHz
Memory model            : Small
External RAM size       : 0
Data Stack size         : 256
#include <mega8.h>
 #include <stdio.h>
#include <delay.h>
// Alphanumeric LCD functions
#include <alcd.h>
// Declare your global variables here
// Voltage Reference: AREF pin
#define ADC_VREF_TYPE ((0<<REFS1) | (0<<REFS0) | (0<<ADLAR))
  float adc=0;
unsigned char lcd[16];
// Read the AD conversion result
unsigned int read_adc(unsigned char adc_input)
ADMUX=adc_input | (ADC_VREF_TYPE & 0xff);
// Delay needed for the stabilization of the ADC input voltage
delay_us(10);
// Start the AD conversion
ADCSRA|=0x40;
// Wait for the AD conversion to complete
while ((ADCSRA & 0x10)==0);
ADCSRA|=0x10;
return ADCW;
void main(void)
// Declare your local variables here
// Input/Output Ports initialization
// Port B initialization
// Function: Bit7=In Bit6=In Bit5=In Bit4=In Bit3=In Bit2=In Bit1=In Bit0=In
DDRB=0xff;
// State: Bit7=T Bit6=T Bit5=T Bit4=T Bit3=T Bit2=T Bit1=T Bit0=T
PORTB=(0<<PORTB7) | (0<<PORTB6) | (0<<PORTB5) | (0<<PORTB4) | (0<<PORTB3) | (0<<PORTB2) | (0<<PORTB1) | (0<<PORTB0);
// Port C initialization
// Function: Bit6=In Bit5=In Bit4=In Bit3=In Bit2=In Bit1=In Bit0=In
DDRC=(0<<DDC6) | (0<<DDC5) | (0<<DDC4) | (0<<DDC3) | (0<<DDC2) | (0<<DDC1) | (0<<DDC0);
// State: Bit6=T Bit5=T Bit4=T Bit3=T Bit2=T Bit1=T Bit0=T
PORTC=(0<<PORTC6) | (0<<PORTC5) | (0<<PORTC4) | (0<<PORTC3) | (0<<PORTC2) | (0<<PORTC1) | (0<<PORTC0);
// Port D initialization
DDRD=0xff;
PORTD=(0<<PORTD7) | (0<<PORTD6) | (0<<PORTD5) | (0<<PORTD4) | (0<<PORTD3) | (0<<PORTD2) | (0<<PORTD1) | (0<<PORTD0);
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: Timer 0 Stopped
TCCR0=(0<<CS02) | (0<<CS01) | (0<<CS00);
TCNT0=0x00;
// Timer/Counter 1 initialization
// Clock value: Timer1 Stopped
// Mode: Normal top=0xFFFF
// OC1A output: Disconnected
// OC1B output: Disconnected
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer1 Overflow Interrupt: Off
// Input Capture Interrupt: Off
// Compare A Match Interrupt: Off
// Compare B Match Interrupt: Off
TCCR1A=(0<<COM1A1) | (0<<COM1A0) | (0<<COM1B1) | (0<<COM1B0) | (0<<WGM11) | (0<<WGM10);
TCCR1B=(0<<ICNC1) | (0<<ICES1) | (0<<WGM13) | (0<<WGM12) | (0<<CS12) | (0<<CS11) | (0<<CS10);
// Timer/Counter 2 initialization
// Clock value: Timer2 Stopped
// OC2 output: Disconnected
ASSR=0<<AS2;
TCCR2=(0<<PWM2) | (0<<COM21) | (0<<COM20) | (0<<CTC2) | (0<<CS22) | (0<<CS21) | (0<<CS20);
TCNT2=0x00;
OCR2=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=(0<<OCIE2) | (0<<TOIE2) | (0<<TICIE1) | (0<<OCIE1A) | (0<<OCIE1B) | (0<<TOIE1) | (0<<TOIE0);
// External Interrupt(s) initialization
// INT0: Off
// INT1: Off
MCUCR=(0<<ISC11) | (0<<ISC10) | (0<<ISC01) | (0<<ISC00);
// USART initialization
// USART disabled
UCSRB=(0<<RXCIE) | (0<<TXCIE) | (0<<UDRIE) | (0<<RXEN) | (0<<TXEN) | (0<<UCSZ2) | (0<<RXB8) | (0<<TXB8);
// Analog Comparator initialization
// Analog Comparator: Off
// The Analog Comparator's positive input is
// connected to the AIN0 pin
// The Analog Comparator's negative input is
// connected to the AIN1 pin
ACSR=(1<<ACD) | (0<<ACBG) | (0<<ACO) | (0<<ACI) | (0<<ACIE) | (0<<ACIC) | (0<<ACIS1) | (0<<ACIS0);
// ADC initialization
// ADC Clock frequency: 1000.000 kHz
// ADC Voltage Reference: AREF pin
ADMUX=ADC_VREF_TYPE & 0xff;
   ADCSRA=0x83;
// Alphanumeric LCD initialization
// Connections are specified in the
// Project|Configure|C Compiler|Libraries|Alphanumeric LCD menu:
// RS - PORTD Bit 5
// RD - PORTD Bit 6
// EN - PORTD Bit 7
// D4 - PORTB Bit 2
// D5 - PORTB Bit 3
// D6 - PORTB Bit 4
// D7 - PORTB Bit 5
// Characters/line: 16
lcd_init(16);
   lcd_clear();
while (1)
   adc=read_adc(0)/204.6;
   lcd_gotoxy(0,0);
   sprintf(lcd,"%f",adc);
   lcd_puts(lcd);
   delay_ms(100);
     if  ( adc >=2.5)//
   PORTB.1=0;  //turn heater off
   else if (adc <=2.5)//
   PORTB.1=1 ; //turn heater on
it is connected to 5 volt supply
You do realise this will not turn anything off!!
1 or 0 still equals 1..
C:
TCCR1A &= ~((1<<COM1A1) | (1<<COM1A0) | (1<<COM1B1) | (1<<COM1B0) | (1<<WGM11) | (1<<WGM10));
Will clear the bits.... But!! The whole register... TCCR1A = 0; is easier..
it is working with internal oscillator but when i use external 8 Mhz oscillator it doesn't work
C:
Project :
Version :
Date    : 31/01/2018
Author  :
Company :
Comments:
Chip type               : ATmega8
#include <mega8.h>
#include <delay.h>
 float adc; int currentValue;
ADMUX=adc_input | ADC_VREF_TYPE;
delay_us(10);
ADCSRA|=(1<<ADSC);
while ((ADCSRA & (1<<ADIF))==0);
ADCSRA|=(1<<ADIF);
return ADCW;
void main(void)
// Function: Bit7=In Bit6=In Bit5=Out Bit4=Out Bit3=Out Bit2=Out Bit1=Out Bit0=Out
DDRB=(0<<DDB7) | (0<<DDB6) | (1<<DDB5) | (1<<DDB4) | (1<<DDB3) | (1<<DDB2) | (1<<DDB1) | (1<<DDB0);
// State: Bit7=T Bit6=T Bit5=0 Bit4=0 Bit3=0 Bit2=0 Bit1=0 Bit0=0
DDRD=(0<<DDD7) | (0<<DDD6) | (0<<DDD5) | (0<<DDD4) | (0<<DDD3) | (0<<DDD2) | (0<<DDD1) | (0<<DDD0);
TCNT0=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
ASSR=0<<AS2;
TCNT2=0x00;
OCR2=0x00;
// ADC Clock frequency: 250.000 kHz
ADMUX=ADC_VREF_TYPE;
ADCSRA=(1<<ADEN) | (0<<ADSC) | (0<<ADFR) | (0<<ADIF) | (0<<ADIE) | (0<<ADPS2) | (0<<ADPS1) | (0<<ADPS0);
while (1)
  currentValue= read_adc(0) ;
    PORTB=ADCW;
By default the atmega8 uses internal oscillator your code looks ok just a little long for what your doing.
I'd say your fuse not set right.
Post code with code tags its easier to read.
Project :
Version :
Date : 31/01/2018
Author :
Company :
Comments:
Chip type : ATmega8
#include <mega8.h>
#include <delay.h>
delay_us(10);
ADCSRA|=(1<<ADSC);
ADCSRA|=(1<<ADIF);
return ADCW;
void main(void)
TCNT0=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
ASSR=0<<AS2;
TCNT2=0x00;
OCR2=0x00;
while (1)
PORTB=ADCW;
Iam trying to use ADC of atmega 8 with external 8 MHz oscillator. the adc result is sent to PORTB and i tested it using led. now i want to compare the result to toggle led on portb but it doesn't toggle.It's working in simulation but doesn't in real hardware
I change ADC using potentiometer on channel 0.
Chip type : ATmega8
#include <mega8.h>
#include <stdlib.h>
#include <stdio.h>
#include <delay.h>
#include <alcd.h>
// char str[16]; //allocate on lcd
delay_us(10);
ADCSRA|=(1<<ADSC);
ADCSRA|=(1<<ADIF);
return ADCW;
void main(void)
// ADC Clock frequency: 62.5 kHz
ADCSRA=(1<<ADEN) | (0<<ADSC) | (0<<ADFR) | (0<<ADIF) | (0<<ADIE) | (1<<ADPS2) | (1<<ADPS1) | (1<<ADPS0);
lcd_init(16);
lcd_clear();
while (1)
adc=currentValue/204.6; //(Arerf connected to 5 v )
if ( adc >=2.5 )
PORTB.1=0; // turn heater off
else
PORTB.1=1 ;// turn heater on
CLKSEL3..1 set to 111 and also set CLKOPT to 1
I also measured 5 v on the activated analog channel (pc0) is that normal?
No, thats not normal.
The Voltage here can float, when nothing is conected.
But "hard" 5V should be not there.
When You want to use the 5V Supply as Voltage reference, You should take the AVCC as reference and put a 10nF Capacitator at the AREF Pin ( when want to change to internal reference later).
ATMEL suggest's to put an 10µH Inductor into the line to the AVCC pin.
When using the A/D Converter of an AVR, the load of the Port's should be as low as possible.
High load's at the Port pins falsify the A/D Result.
When Your Circuit doesnt work with an crystal, the fuses can be false, the capacitators of the crystal have any problems, or the crystal is faulty.
When the lines to the crystal are to long, it can be a cause too.
