AND Gate
cyclops_returns
I'm looking for an and gate with a positive output(I know that sounds stupid but i found one where the out put is negative:Transistor Gates). I also found one which uses diodes but it doesn't seem to work. Can you suggest something. Alternatively can you suggest a pnp transistor that's commonly available. I'm from India, if that helps.
Thanks in advance
The first one in the link is a positive output AND gate, further down the page is a negative output AND gate called a NAND.
Thanks in advance
Post the schematic that this gate fits into. Sometimes just two diodes will work as an AND gate.
Thanks for the help. It turns out I was just being stupid, the transistor gate works fine. But can you please explain me how the diode gate will work, I feel that the output will always be high regardless of the input
Thanks for the idea of attaching the inverter, quite practical but i just wanted to be minimal.
If both the A and B input is held HIGH, neither diode will have a voltage drop, there will be no current flow; no current flow means no IR drop across the resistor, hence V will appear at the output (a HIGH).
If either or both the A and/or B input is grounded (a logical LOW), either or both diodes will be forward-biased and current will flow between V and ground through one or both diodes. This current will cause an IR drop across the resistor equal to about (V-0.7v) leaving the remainder (0.7v) at the output for a logical LOW. It's not the best circuit in the world, for that's a sloppy LOW, assuming silicon diodes. Using germanium diodes, the output would be closer to 0.3v for a logical LOW, maybe 0.1 to 0.2v using hot carrier (Schottky) diodes. So, it does work as an AND gate: if both A AND B is HIGH, the output is HIGH; in all other cases, the output is LOW. This also translates to a DeMorgan equivalent AND: If either A or B goes LOW, the output goes LOW; in all other cases the output is HIGH.
Dean
