Yes.OK then i will try 220pf as a coupling capacitor for higher output and for higher range. I think higher voltage output will cause higher radiation at antenna. Can i think like this way?
Here is my file:(i tried LTSpice IV but cant simulate. I made schematic but failed on last stage of 'simulate'. I have no guide about it.)
It was NOT designed properly. The designer tried it with only one transistor (it had low hFE) then maybe it worked. I simulated it with a "typical" transistor that has "typical" hFE and it distorts very badly because it is almost always saturated. If the hFE is even higher then it is worse.Check this FM Tx . It has a preamp without pre-emphasis. Can I simply add 470 ohm bypassed resistor with 100nf at emitter and 100pf from base to emitter (like on mod 4) to add pre-emphasis?
An RC circuit with a time-constant of 50us has a cutoff frequency (+3dB for pre-emphasis) of 1/(2 x pi x 50us)= 3200Hz.- Actually what is mean by '50 microsecond' in pre-emphasis?
A 47k emitter resistor probably will not work with a transistor but it is fine with an opamp.What might be the difference between (470x100nf)=47uS and (47Kx1nf)=47uS? I think it has difference in voltage pass, Not in audio pass.
Probably your receiver is cheap and it was overloaded by the very strong signal. My high quality home stereo FM tuner and high quality car radio do not get overloaded.Once, I tried 9V for all 3 stages of Mod-4, but got noise and noise and noise.... almost at all frequencies 88 to 108 MHz in receiver
You must not have the transmitter operate at the aircraft communications band which is directly above the FM broacast band.I want to use 8 or 9 v regulated supply for little high output if i can. Probably the freq. might be out of FM band at that voltage due to high voltage at oscillator and also there might be bias factor for preamp too. Which few value should i have to change? If it is complicated, just leave it.
Yes.
Here is my file:
EDIT: my file does not run because the associated files can not be uploaded.
