Dear All,
We are using bq2060a for one of our battery operated device. We face a critical issue with the gas gauge.
When the device is off , the load current is around 700 uA. But the Remaining capacity() is decreasing at a rate of 7 mAh. What could be the likely reason?
We have put a sense resistor of 100 milli ohm. The DMF threshold is set as 50 uV. Please leave your mail id incase if you have faced the issue before. I will contact you personally.
THanks,
Datta
THanks,
Datta
