xxxxxxxxxxxxxx
Hello everyone,
I have recently aquired a JA-S11 Model, JVC brand stereo amplifier. Of course, it doesnt work.
The power supply works and is OK, the power light lights, but there is no click or pop from and speakers on any chanel. There are no other indicator lights.
The unit does not give any output on any chanel when a source, high or low volume, is connected to any input.
Inside, everything is visualy OK, but when the unit is powered up, regardless wheather or not there is an input, the right-chanel amp chip (SanKen S-40W, photo attached) heats up to a moderate-high level, but the other amp chip doesnt warm at all. Remember that neither output works.
No other parts get hot or are obviously damaged pysicaly. There is, however, a small relay which does not seem to be triggering under any circumstances (set by the function switches on the front panel). This relay is a 24v type, and works (tested out-of-circuit), however, the circuitry that triggers it may or may not be functional.
Any suggestions? All help is appreciated (And if you have a service manual that I dont have to pay $20 for, I'd love to know
) By the way, there is no info for what i'm doing on the net (or that i can find).
Thanks everyone
PS: As a side-question, I've attached a diode that has a coloured (yellow) stripe on it. Now i've seen this stuff before but what does this mean (part-wise)? This also appears on SMD diodes. Love to know if you do, thanks again
Thanks everyone
