jrz126
Active Member
I'm working on this simulator at work and I need a way to transfer files over RS232 using Labview. I'm able to do simple commands over the line, (like change directory), but I need a way to transfer a couple of small INI files.
I googled a bunch and I think I might need some sort of extra library or something that supports Xmodem transfer.
The serial connection is at 38400 8 bit, no parity and uses Xon Xoff flow control? Also, the labview is running on a linux server as well.
