any prof. in programming here?
zemo161985
i want any prof. to read this (mikro c) and tell me what is the error and the correctionand if he is very professional send it completed and corrected on my e_mail: zimo161985@yahoo.com
note : we are using pic16f877a+max232+nokia6210+lcd
our goal is to send sms to the pic and get the report back
here is the code:
Microcontroller Code in C
Main program.h
#include "test1.h"
#include <LCD.C>
#include <input.c>
//#include <string.h>
//#include "internal_eeprom.c"
#include "nokia61.c"
unsigned char* get_data () //example
unsigned char buff[];
unsigned char data;
int i=0;
while (1)
data=getc();
if (data != 0x00)
buff[i++]= data;
else
break;
buff='\0';
return buff;
unsigned char* get_data2 () //mobile
unsigned char data;
int i=0;
int msg_found = 0;
while (1)
data=getc();
if (data == 0x03)
msg_found = 1;
else
if (data == 0x2E)
break;
else
if (msg_found)
buff[i++]= data;
buff='\0';
return buff;
void putstr(unsigned char* data)
unsigned char i;
i=0;
while (data != 0x00)
putc(data[i++]);
int comp (unsigned char* s , unsigned char* d , int len)
int i,count =0;;
for (i=0; i<len ;i++)
if( s == d)
count++;
if (count == len)
return 1;
else
return 0;
void copy (unsigned char* d , unsigned char* s , int len)
int i,count =0;;
d = s;
void main(unsigned char* s)
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DISABLED,0,1);
setup_comparator(NC_NC_NC_NC);
setup_vref(FALSE);
SET_TRIS_A(0x00);
OUTPUT_A (0x00);
lcd_init();
unsigned char r[20];
unsigned char s1[7]= "Light1";
unsigned char s2[7]= "Light2";
unsigned char s3[7]= "Light3";
unsigned char l1[14] = "light1 on";
unsigned char l2[14] = "light2 on";
unsigned char l3[14] = "light3 on";
unsigned char smsc[13] = "+20122000020";
unsigned char phone[11] = "0122337666";
while (1)
strcpy(r,rsms());
print(r);
if (comp(r,s1,7))
OUTPUT_HIGH(PIN_A0);
init();
delay_ms(109);
n61_smssendfull(smsc ,phone, l1 ,0x60);
else
if (comp(r,s2,7))
OUTPUT_HIGH(PIN_A1);
init();
delay_ms(109);
n61_smssendfull(smsc ,phone, l2 ,0x60);
else
if (comp(r,s3,7))
OUTPUT_HIGH(PIN_A2);
init();
delay_ms(109);
n61_smssendfull(smsc ,phone, l3 ,0x60);
init();
Nokia.c
#include <string.h>
#include "encry.h"
// **** Functions ****
unsigned char n61_recver();
unsigned char n61_recsenc();
unsigned char recsms (unsigned char);
void n61_sendack(unsigned char ,unsigned char);
// ** Code **
void init()
int i;
for (i=0; i<128;i++)
putc(0x55);
void print(unsigned char* data )
unsigned char i=0;
while(data)
lcd_putc(data[i++]);
static short timeout_error;
char timed_getc() {
long timeout;
timeout_error=FALSE;
timeout=0;
while(!kbhit()&&(++timeout<302))
delay_us(3);
if(kbhit())
return(getc());
else {
timeout_error=TRUE;
return(0);
void n61_sendframe(unsigned char type, unsigned char size, unsigned char *data)
unsigned char buf[80];
int at, n, len;
unsigned int *p;
unsigned char check1 = 0;
unsigned char check2 = 0;
at = 0;
// build header
buf[at++] = 0x1e; // message startbyte
buf[at++] = 0x00; // dest: phone
buf[at++] = 0x0c; // source: PC
buf[at++] = type;
buf[at++] = 0x00;
buf[at++] = size;
// add data
for(n = 0; n < size; ++n)
buf[at++] = data[n];
// if odd numbered, add filler byte
if(size % 2) {
buf[at++] = 0x00;
// calculate checksums
p = buf;
len = at;
for(n = 0; n < len; ++n)
check1 ^= buf[n++];
check2 ^= buf[n];
buf[at++] = check1;
buf[at++] = check2;
// send the message!
for(n = 0; n < at; ++n) {
putc(buf[n]);
void n61_sendack(unsigned char type, unsigned char seqnum)
char buf[10];
unsigned char n,check1,check2;
check1 = 0;
check2 = 0;
buf[0] = 0x1E;
buf[1] = 0x00;
buf[2] = 0x0C;
buf[3] = 0x7f;
buf[4] = 0x00;
buf[5] = 0x02;
buf[6] = type;
buf[7] = seqnum;
for(n = 0; n < 8; ++n)
check1 ^= buf[n++];
check2 ^= buf[n];
buf[8] = check1;
buf[9] = check2;
for(n = 0; n < 10; ++n)
putc(buf[n]);
unsigned char n61_ackwait(unsigned char seqnum)
unsigned char i,No;
unsigned char buf[10];
// while(1)
if (timed_getc() == 0x1E)
buf[0] = 0x1E;
for (i = 1 ;i<10;i++)
buf = getc();
if ((buf[3] == 0x7f) && ( buf[7] == (seqnum & 0x07) ) && ( ( buf[7] & 0xF0) != 0x80 ) )
return 1;
else
return 0;
break;
void n61_askforver (unsigned char seqnum)
unsigned char ver[7] = {0x00 ,0x01 ,0x00 ,0x03 ,0x00 ,0x01 ,0x00};
ver[6] = seqnum;
n61_sendframe(0xD1 ,7 ,ver);
if (n61_ackwait(seqnum))
n61_recver();
break;
void n61_senc (unsigned char seqnum)
unsigned char senc[6] = {0x00 ,0x01 ,0x00 ,0x01 ,0x01 ,0x00};
senc[5] = seqnum;
n61_sendframe(0x04 ,6 ,senc);
n61_recsenc();
break;
unsigned char i,No;
unsigned char buf[46];
while(1)
if (getc() == 0x1E)
buf[0] = 0x1E;
for (i = 1 ;i<46;i++)
buf = getc();
if (buf[3] == 0xD2)
n61_sendack(0xD2 ,buf[43] & 0x07);
return 1;
else
n61_sendack(0xD2 ,buf[43] | 0x80);
return 0;
break;
unsigned char i,No;
unsigned char buf[20];
while(1)
if (getc() == 0x1E)
buf[0] = 0x1E;
for (i = 1 ;i<20 ;i++)
buf = getc();
if (buf[3] == 0x04)
n61_sendack(0x04 ,buf[16] & 0x07);
return 1;
else
n61_sendack(0xD4 ,buf[16] | 0x80);
return 0;
break;
int n61_smssendfull(char *smsc ,char *dest ,char *msg ,unsigned char seqnum)
while (1)
int n;
// standard frame data header
buf[0] = 0x00;
buf[1] = 0x01;
buf[2] = 0x00;
// send sms
buf[3] = 0x01;
buf[4] = 0x02;
buf[5] = 0x00;
// smsc
memset(buf + 6, 0, 12);
n61_bcd(buf + 6, smsc);
// TPDU ?
buf[18] = 0x15;
// misc
buf[19] = 0x00; // message ref
buf[20] = 0x00; // protocol ID
buf[21] = 0x00; // data coding scheme (non-flash)
// message size
buf[22] = strlen(msg);
// destination
memset(buf + 23, 0, 12);
n61_bcd2(buf + 23, dest);
// validity period
buf[35] = 0xA7;
// filler
buf[36] = 0;
buf[37] = 0;
buf[38] = 0;
buf[39] = 0;
buf[40] = 0;
buf[41] = 0;
// the string
n61_pack7(buf + 42, msg);
buf[ 42 + buf[22]] = 0x01;
buf[ 43 + buf[22]] = seqnum;
n61_sendframe (0x02 ,44 + buf[22] ,buf);
if (n61_ackwait (buf[43 + buf[22]]))
break;
unsigned char recint (unsigned char seqnumn)
unsigned char i,No;
unsigned char buf[18];
// for (i = 0 ;i<11 ; i++)
buf[0] = 0x1E;
for (i = 1 ;i<18;i++)
buf = getc();
if (buf[3] == 0x02 && buf[5] == 0x09)
n61_sendack (0x02, (buf[14] & 0x07));
// print(recsms(seqnumn));
return 1;
break;
return 0;
unsigned char recint2 ()
unsigned char i,No;
while(1)
if (getc() == 0x1E)
buf[0] = 0x1E;
buf = getc();
if (buf[3] == 0x0D)
n61_sendack (0x0D, (buf[16] & 0x07));
return 1;
else
return 0;
break;
unsigned char* rsms ()
unsigned char type;
unsigned char size,seqnum;
unsigned char buf[60];
int i=0;
unsigned char del[8] ;
while(1)
if (getc() == 0x1E)
getc();
getc();
type = getc();
getc();
size = getc();
if (type == 0x02)
for(i=0 ;i<size ;i++)
buf = getc();
getc();
getc();
getc();
if (buf[3] == 0x10)
size = buf[22];
seqnum = buf[48];
n61_sendack (0x02, seqnum & 0x07);
// recint2();
// recint2();
delay_ms(906);
//delete msg
while (1)
init();
delay_ms(109);
del[0] = 0x00;
del[1] = 0x01;
del[2] = 0x00;
del[3] = 0x0A;
del[4] = buf[4];
del[5] = buf[5];
del[6] = 0x01;
del[7] = 0x60;
n61_sendframe (0x14 ,8 ,del);
if (n61_ackwait(seqnum & 0x07))
break;
// buf[42 + size] = '\0';
return(n61_unpack7(buf + 42 , size));
break;
break;
There is a button # that you wrap around your code when posting.
PS what compiler includes
 [B]#include "nokia61.c"[/B]
The code is of limited utility without a schematic and some infomation on the device you are talking to.
I do this kind of thing for a living so I guess I fit the bill for a prof.(essional). I am curious to know if the problem is with getting the code to compile or getting it to operate the way you think it should.
You have given us no clue as to your expectations of correct behavior. I'm afraid you given us far to little to work with. I usually charge $150/hr for this kind of disaster recovery work, I guess that also qualifies me as a prof.(essional)
