Anyone in UK programme some PICs for me???
Mr Chris
Hello, Im new to the forum, so hello everyone! Can anyone help out here? I will obviously pay you for your time/expertise/goodwill. I need a simple timer that will give a momentry 'on' once every 24 hours. Permanently connected to a 5 volt supply it would need to switch a micro relay on (so a pin high) for say 2 seconds once in every 24 hours. It is to force a hard reset on some telematics equipment, so as you can appreciate neither the 24 h or the 2 sec is too critical, just roughly once every day. I had a code supplied for a 10F chip (dont know why), but my programmer doesnt support this device.
It would be far easier just to get one of you guys to supply a hex file for a different device or a programmed chip that I could copy. Ideally no other components, just pic and relay, physical space is tight as it is being installed into existing equipment.
I realise its no big challenge but I would really appreciate any help with this!
Chris
Hi Chris,
Would you like me to rewrite that code for another chip Sir?
Regards, Mike
<added>
If anyone is interested, here's the original 10F200 code I threw together for Chris on the other forum. It toggles an "activity" LED on GP1 at half second intervals and it toggles the GP0 "relay" pin high for 2 seconds at 24 hour intervals.
;*     OEM timer (GP0 = Relay output, GP1 = Activity LED)         *
;*     MPLAB: 8.50    (tabs=8)                                    *
;*     MPASM: 5.35                                                *
        errorlevel      -302    ; suppress bank warnings
        radix   dec
        include "p10f200.inc"
        __CONFIG   _MCLRE_OFF & _CP_OFF & _WDT_OFF
;--< variables >---------------------------------------------------
delaylo equ     0x13            ; DelayCy() subsystem
delayhi equ     0x14            ; DelayCy() subsystem
hours   equ     0x15            ; Timer sub
minutes equ     0x16            ; Timer sub
seconds equ     0x17            ; Timer sub
;--< defines >-----------------------------------------------------
;  K8LH DelayCy() subsystem macro generates five instructions     '
clock   equ     4               ; 4, 8, 12, 16, or 20 (MHz)
usecs   equ     clock/4         ; cycles/microsecond multiplier
msecs   equ     clock/4*1000    ; cycles/millisecond multiplier
DelayCy macro   delay           ; 12..524298 cycle range
        movlw   high((delay-12)/8)^255
        movwf   delayhi
        movlw   low ((delay-12)/8)^255
        movwf   delaylo
        call    uDelay-((delay-12)%8)
        endm
;  main.init                                                      *
        org     0x000
Init
        movwf   OSCCAL          ; factory INTOSC calibration
        movlw   b'00001000'     ;
        tris    GPIO            ; GP3 input, all others output
        clrf    GPIO            ; clear output latches
        movlw   b'10011110'     ; 10011110
                                ; 1-------, IOC off
                                ; -0------, weak pullups on
                                ; --0-----, T0CS source Fosc/4
                                ; ---1----, T0SE edge hi>lo
                                ; ----1---, PSA prescale WDT
                                ; -----110, PS prescaler 64
        option                  ; set OPTION reg'
;  main.loop                                                      *
cycle
        DelayCy(500*msecs)      ; burn off 1-sec minus overhead
        DelayCy(500*msecs-16)   ;
        movlw   23              ; 23:59:58 "off" time
        btfsc   GPIO,0          ; off? yes, skip, else
        movlw   0               ; 00:00:02 "on" time
        movwf   hours           ;
        movlw   59              ;
        btfsc   GPIO,0          ;
        movlw   0               ;
        movwf   minutes         ;
        movlw   57              ;
        btfsc   GPIO,0          ;
        movlw   1               ;
        movwf   seconds         ;
timer
        DelayCy(500*msecs-19)   ; 1 sec minus 22 cycle loop time
        movf    GPIO,W          ;
        xorlw   2               ;
        movwf   GPIO            ; toggle LED on GP1 pin
        DelayCy(500*msecs-3)    ;
        movf    GPIO,W          ;
        xorlw   2               ;
        movlw   59              ; W = 59 (mins/secs reset value)
        decf    seconds,F       ; decrement seconds
        btfsc   seconds,7       ; negative? no, skip, else
        decf    minutes,F       ; decrement minutes
        movwf   seconds         ; reset seconds = 59
        btfsc   minutes,7       ; negative? no, skip, else
        decf    hours,F         ; decrement hours
        movwf   minutes         ; reset minutes = 59
        movf    seconds,W       ;
        iorwf   minutes,W       ;
        iorwf   hours,W         ; timer timed-out?
        skpz                    ; yes, skip, else
        goto    timer           ; branch
        movf    GPIO,W          ;
        xorlw   1               ;
        movwf   GPIO            ; toggle GP0 output
        goto    cycle           ; loop (new cycle)
;  K8LH DelayCy() subsystem 16-bit "uDelay" timing subroutine     *
        nop                     ; (delay-12)%8 == 7 entry point
        nop                     ; (delay-12)%8 == 6 entry point
        nop                     ; (delay-12)%8 == 5 entry point
        nop                     ; (delay-12)%8 == 4 entry point
        nop                     ; (delay-12)%8 == 3 entry point
        nop                     ; (delay-12)%8 == 2 entry point
        nop                     ; (delay-12)%8 == 1 entry point
uDelay  incf    delaylo,F       ; subtract one 8-cycle loop
        skpnz                   ; borrow? no, skip, else
        incfsz  delayhi,F       ; done?  yes, skip, else
        goto    uDelay-3        ; do another 8-cycle loop
        retlw   0               ;
        end
<added>
Attached program source and hex for 12F629 device...
  • Chris' OEM Timer.asm.txt
  • Chris' OEM Timer.HEX.txt
Timer
Thanks Mike (and others). I cobbled a 12f and a few other components together and added them to a telematics unit. (This is the unit we need to force a reset on) I set it up so it will activate an input on the unit, so sending an event code to the server. This way I can monitor the 'reset' times from the server stats.
fingers crossed.....
Good luck Chris. Let us know how it works out.
If you like, I could modify that code to output every 30 seconds, or something like that, to help you verify operation in a more timely fashion.
Regards, Mike
timer
Yes, I thought of that too, might have been a good idea to test eh?
I might ask you to modify code for something else, will let you know.
Cheers for now.
Hi Chris,
Here are modified program files with a 60 minute cycle time that may help you qualify the hardware and software in a more timely fashion.
Cheerful regards, Mike
