Anyone tried PDF Creator?
Hero999
Banned
  • Rectifier.pdf
I think I might have used that at some point--I've certainly used PDF virtual printer devices. At the moment I just use the "PDF" printer presented by CUPS. Does everything I need (i.e. just sends the output to a PDF file in ~/PDF/). That's on Ubuntu 8.04.
Torben
I have it installed on my PC and it works great.
Same here. I've been using it for a couple of years and it's been really useful! I think it's a must-have software.
Torben
I've never tried that on Linux.
The think I like about PDF Creator is that you can combine several print jobs into one PDF; can you do that with CUPS?
Never tried, but I doubt it. :) I mean, it's probably possible to set up some scripts to handle it, but I don't think there's any GUI interface in the cups-pdf virtual printer. It just pretends to be a printer and drops the PDF file into ~/PDF. That's all I've needed so far so I haven't worried about it.
Torben
I prefer PrimoPDF for generating PDF's in windows
it installs as a printer driver and is really good
for linux? cups-pdf :D
open office.org also has a built in pdf creator, also basically a printer driver, but I install pdf creator as well, very handy indeed.
Help a lot if you want to send a document somewhere that you do not want altered in any way. Compresses well too.
I always print to file as a postscript and then use distiller to create the PDF
PDF Creator would be a better approach as all you need to do when creating the PDF is select print from your application, then a select printer window pops up and you select PDF creator instead of your printer. Viola ... PDF creator works with every app I have that has a print option.
