Application note
Can anyone tell me from where i can get application note on 5KW current fed Dual Active Bridge? I am a newbie and have never worke on a hardware design on my own. So a good application note would be really helpful. Thanking in advance
Did a quickie google of "5KW current fed Dual Active Bridge":
First listed was this IEEE Pub.
Applications lower down.
Just curious.
A CF DAB is not a simple device to design (your stated goal) or build. I haven't tried, but from what I've seen, component selection, alone, requires a good deal of effort and expertise.
As a self proclaimed newbie (however you describe that appellation), why are you starting with such a difficult project?
Just curious.
because I don't have any other choice. I have to do it
Just curious.
Trying to simulate this topology but I am having a hard time to understand this paper especially the stages. Can anyone help with this. I will be highly obliged. Thanking in anticipation.
  • 3ph-min.pdf
Agree with Cowboybob.
Not to discourage you, but.......
Such a complex project is not something that can be explained in a hobbyist forum.
What you show as an example looks very much like a fully-regenerative three phase AC motor drive inverter.
The principles of one of these may help:
In industrial gear, most drives that small (5 KW) just use a braking resistor to dump excess regenerated power, but they are cheap..
Bigger ones may be an all-in-one unit or modular, with the input section as a power supply with DC out, feeding one or several separate DC to AC inverters & allowing any to feed power back via regeneration as needed.
eg. see the "infeed" and "power" module sections in here:
