ARDUINO MEGA 2560 WITH ILI9341
umairml
Unable to get display on ili9341 using arduino mega 2560?
I have no specific code to run please guide me....
Have you set the IM pins correctly for SPI operation..?
E
here is all i am doing. Now please guide me what is wrong with my code or my circuit simulation.
My brain is exploding....
Please help
  • UTFT_demo_fast_2.ino
  • ili9341arduino.zip
Hi Umairml .. .
Welcome to ETO .. .. .
I'm not sure you have your interface connections right yet, they don't seem to match those on the ILI9341 datasheet.
I would suggest you use one of the example sketches in Arduino IDE to make sure your connections/setup is correct before you try to run a more complex sketch.
Look here .. ..
Then when you have that running correctly you have a fighting chance with the more complex sketch.
I hope that helps .. ..
S
IM0 low IM1~3 high
Yes, currently shown as IM1 = low; IM0, 2 & 3 high.
Also interface between screen and Arduino - I can't read the pin ID's on the screen ( ageing eyesight ) but they don't look right ? The Arduino example sketches have the pin ID's marked out to make it easy to identify them.
S
h,
You show a Vs =1.5v, does that fall within the specified range.?
E
There was wiring issue after correct connection and using of correct library with arduino it is now working. Actually i was using library of arduino uno after search i got that it was uno library as pin initialization was wrong but all good now after reading arduino datasheet.
