Arduino Wiring Jetpack Lights and Sound (Battery, 2 amps, 3 speakers, 2x 61 led neopixel rings & 5V motor)
MT_Space
Hi everyone,
Hope you are doing well. I was wondering if this circuit is wired correctly to an Arduino Uno and if I need any resistors or capacitors or anything to make sure it will work properly and safely. I also don't know what kind of battery to use. Can I just use a multimeter to find out the current for everything and buy a battery based on that? I can't find data sheets for all the components. Here is a picture of the circuit diagram. Any help would be appreciated.
The circuit is programed on an Arduino Uno. The code runs so that when a button is pressed Amp 1 starts playing along with the motor starting. Then, the neopixel rings start to fade in and then twinkle. After 4 seconds Amp 2 plays while the lights still twinkle. When the button is released Amp 1 plays, the motor shuts off and the lights fade out.
