So, I've had a working setup (Dell laptop running XP, MPLAB, ATEN usb->RS232, Inchworm+) for a while. I needed to re-image my laptop since it had gotten slow and fragmented (same install for over 3 years).
When I re-install MPLAB, all I could get was the error
ICD0019: Communications: Failed to open port: (Windows::GetLastError() = 0x2, 'The system cannot find the file specified.')
ICD0021: Unable to connect with MPLAB ICD 2
Loopback test on the inchworm worked, and it didn't matter what com port, setting, etc.. I selected, I always got this error. I tried mplab 7.60, 8.02. I tried different USB drivers. I tried all the settings.
After screwing around for several hours, I finally loaded the bluetooth drivers. Everything started working. Apparently there are 9 COM ports used by the bluetooth card built into the laptop, and they were all interferring with the USB to RS232 adapter.
I figured since I had googled this error and hadn't found anything useful, I'd at least write it up here for posterity sake.![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
