ARM STMF32103 Clock settings
Hi All,
is there a minimal program to set the clock of the stmf32103 to 72Mhz.
I have written an FSMC LCD code and when I write 240*100 pixels, it takes about 0.1secs, so there should
Hi All,کنترل هوشمند اندروید خانه لوازم برقی منزل ریموت Android پروژه الکترونیک میکروکنترلر
Are you using CMSIS libs?
If yes try
void SetSysClockTo72(void)
  /* SYSCLK, HCLK, PCLK2 and PCLK1 configuration -----------------------*/
  /* RCC system reset(for debug purpose) */
  RCC_DeInit();
  /* Enable HSE */
  RCC_HSEConfig(RCC_HSE_ON);
  /* Wait till HSE is ready */
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if (HSEStartUpStatus == SUCCESS)
    /* Flash 0 wait state */
    FLASH_SetLatency(FLASH_Latency_0);
    /* HCLK = SYSCLK */
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    /* PCLK2 = HCLK */
    RCC_PCLK2Config(RCC_HCLK_Div1);
    /* PCLK1 = HCLK */
    RCC_PCLK1Config(RCC_HCLK_Div1);
    /* PLLCLK = (8MHz) * 9 = 72 MHz */
    RCC_PREDIV1Config(RCC_PREDIV1_Source_HSE, RCC_PREDIV1_Div1);
    RCC_PLLConfig(RCC_PLLSource_PREDIV1, RCC_PLLMul_9);
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
    /* Wait till PLL is ready */
    while (RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    /* Select PLL as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    /* Wait till PLL is used as system clock source */
    while (RCC_GetSYSCLKSource() != 0x08)
  else
    /* If HSE fails to start-up, the application will have wrong clock configuration.
       User can add here some code to deal with this error */
    /* Go to infinite loop */
    while (1)
[/cod]
