Artificial horizon indicator for RC airplanes
Technowanabee
Recently I saw an Electronic Flight Information System (EFIS) for full size aircraft which uses a Compac iPac for its display-including the AHI. I would like to attempt creating just the AI which -I think- is reading two axis, pitch and roll. The Futaba PA1, or 2, autopilot senses movement about these axis and sends a signal to the aileron or elevator to correct to level flight. If you took these 2 signals and sent them to..........? Could this be turned into such an instrument. Why? to observe movement when flying with a video TX. With my GPS and Video Display Overlay, I get airspeed. lat/lon, altitude, and direction. Any thoughts? Thanks. Bill
Check out these Dual Axis Accelerometers from analog devices.They are very small(5mmx5mm) and relatively cheap.They can accurately measure static acceleration on two axes(pitch and roll).
With analog ouptut:
with PWM output:
