ChriX
Good evening all. I wonder if anyone can see anything immediately wrong with my code excerpt below. I have spent a LONG time debugging this and I cannot get it to work as intended.
I put together a quick 64x16 LED matrix panel using shift registers, and am trying to drive it using a 16F870. I am driving it such that the rows are cycled top to bottom, and for each new row, the 64 bits are shifted in from right to left.
I have had no problem in putting together code to shift it, but the problem comes when I want to try and read a bitmap from a table.
SCREENLOOKUP is called with a value from 0 to 127 held in OFFSET. I have tested this by returning the value of OFFSET directly after SCREENLOOKUP is called, and I correctly get the binary values for 0 to 127 displayed via my LED matrix (see photo - it counts from L-R, T-B). This confirms that the offset value is normal, and that my SR routines are working correctly.
When I try to return the data from the table the chip seems to crash, and when using ICD will occasionally break at 0x00 when it hasn't been asked to, so I guess it's jumping somewhere it shouldn't. The OFFSET is generated as below, the code shows what is executed per row of the display.
Any help appreciated as I have now pretty much destroyed my code trying to work out what is wrong!
org 0x200
SCREENLOOKUP
movlw high(SCREENDATA)
movwf PCLATH
movlw low(SCREENDATA)
addwf OFFSET,W
btfsc STATUS,C
incf PCLATH,F
movwf PCL
SCREENDATA
dt b'11111111', .... (128 bytes organised as 16 lines each with 8 bytes)
movf CURRENT_ROWG,w
clrf CURRENT_ROWT
movwf CURRENT_ROWT
bcf STATUS,C
rlf CURRENT_ROWT,1
rlf CURRENT_ROWT,1
rlf CURRENT_ROWT,1
; shift the 64 cols of data
movlw b'00000000'
iorwf CURRENT_ROWT,W
movwf OFFSET
call SCREENLOOKUP
call SHIFTCOLS
movlw b'00000001'
movwf OFFSET
call SCREENLOOKUP
call SHIFTCOLS
movlw b'00000010'
movwf OFFSET
call SCREENLOOKUP
call SHIFTCOLS
movlw b'00000011'
movwf OFFSET
call SCREENLOOKUP
call SHIFTCOLS
movlw b'00000100'
movwf OFFSET
call SCREENLOOKUP
call SHIFTCOLS
movlw b'00000101'
movwf OFFSET
call SCREENLOOKUP
call SHIFTCOLS
movlw b'00000110'
call SCREENLOOKUP
call SHIFTCOLS
movlw b'00000111'
movwf OFFSET
call SCREENLOOKUP
call SHIFTCOLS
bcf PIN_COL_TR
nop
bsf PIN_COL_TR
bcf PIN_ROW_EN
decf CURRENT_ROWG,f
bcf STATUS,C
rlf CURRENT_ROWL,f
btfsc STATUS,C
goto MOVEUPL
bcf STATUS,C
rlf CURRENT_ROWH,f
btfsc STATUS,C
goto MOVEDOWNL
goto ENDLOOP
MOVEUPL
movlw 1
movwf CURRENT_ROWH
movlw 0
movwf CURRENT_ROWL
goto ENDLOOP
MOVEDOWNL
movlw 1
movwf CURRENT_ROWL
movlw 0
movwf CURRENT_ROWH
; start from zero again on G
movlw b'00001111'
movwf CURRENT_ROWG
ENDLOOP
DELAY_MICRO 250
goto LOOP_BEGIN
