AT89C4051 assembly code compiler question
fiveten
I am having problems converting an .asm code file to hex. The assembler I am using is a demo, it will compile the code and I can run it in a simulator fine. It however will not produce a hex file I can burn to my chip. I have tried other programs, I.E. Keil, sdcc and uc51 along with a few others. The asm code that workis in the demo I have will not work in these other programs. My question is..is there a compiler where I do not have to use C code within my assembly code. I do not have a clue how to program in C. Do I need to learn C first? or is there a program that will work.
Thanks for any help, fiveten
I am having problems with my code. I have pieces this code together from others, it is not all mine. When I run the code in my simulator with the step by step mode I was able to get the lcd to operate. If I use the run feature in my simulator the lcd will not work. It will also not work when I burn it to my 89C4051. This is the code I used. I am a beginner and know I have some errors. Thank you for any feedback.
fiveten
  • lcd.txt
I was able to figure it out, I needed to delay my mpu upon powerup in order to wait for the lcd to power up.
Thanks for you guys how helped me.
fiveten
