Atmega16 & 74ls922 problems
Mortalo
hi guys !!
hope youre doing ok.
im posting this, because im having a rather annoying problem.
what im trying to do is that with a 74ls922 and a keyboard with
4 rows and 3 columns i want to do an access control.
i need a password of 6 digits.
when i press * it erases all i have written to the lcd.
# its "ENTER" with that im reading the eeprom with the 6 digits.
thas the idea more or less, my issue is.
im testing my program on proteus, it works fine, but with my hardware.
im writing to the LCD to see that im getting the right numbers to see if im
on the right way, BUT when i press 1 2 3 it writes to the LCD with no problem
but when i press 4 5 6 it presents 1 2 3 respectively the same with 7 8 9 and with * 0 #. Its like its only writing to the lcd the values of the columns
for example 1 4 7 and * are on the same column, when i press any of this buttons it writes a "1" on the lcd. 2 5 8 0 are on the same column when i press any of this it writes a "2" on the lcd and so on.
im sensing the voltaje on PORTC that is where i enter the data ABCD from the 922 and its sending me the right voltaje, for example for "4"
pc0 = 0, pc1 = 0, pc2 = 1, pc3 = 0 (pc4-pc7 i have them grounded) but it keeps writing a "1" on the LCD.
pd2 i have it conected to data available of 922, and column 4 (X4) i have it
with no connection.
i was gessing that the portc may be damaged but i have 2 mega16 and im getting the same problem.
Can you give me any help ?
Im going to look for a priest, to exorcise this thing
this is my code
and my circuit on proteus is right here
#include <mega16.h>
#include <delay.h>
#include <stdio.h>
#define LCD_DATA PORTA
#define LCD_E    PORTD.6
#define LCD_RS   PORTD.4
unsigned char value;
unsigned char j,w;
unsigned char k =0;
void lcd_busy()
	delay_ms(5);
void lcd_wr_ir(unsigned char cmd)
    LCD_E = 0;
	lcd_busy();
	LCD_RS = 0;		// data register
	LCD_DATA = cmd; // MSN
	LCD_E = 1;
	LCD_E = 0;
	delay_us(200);
	LCD_DATA = cmd << 4; // LSN
	LCD_E = 1;
	LCD_E = 0;
	delay_us(200);
void lcd_wr_dr(unsigned char cmd)
    LCD_E = 0;
	lcd_busy();
	LCD_RS = 1;		// data register
	LCD_E = 1;
	LCD_E = 0;
	delay_us(200);
	LCD_E = 1;
	LCD_E = 0;
	delay_us(200);
void lcd_int()
	// to conect ports to  LCD
	DDRA = (DDRA & 0x0F)| 0xf0;	//  4 msb data port
	DDRD.4 = 1;					// Register select
	DDRD.6 = 1;                 // Enable LCD
	LCD_RS = 0;
	LCD_DATA = 0x30;
	LCD_E = 1;
	LCD_E = 0;
	delay_ms(5);
	LCD_DATA = 0x30;
	LCD_E = 1;
	LCD_E = 0;
	delay_ms(5);
	LCD_DATA = 0x30;
	LCD_E = 1;
	LCD_E = 0;
	delay_ms(5);
	LCD_DATA = 0x20;
	LCD_E = 1;
	LCD_E = 0;
	delay_ms(5);
	lcd_wr_ir(0b00101000);	//  4bits, 1 line, font 5x7
	lcd_wr_ir(0b00000110);  // lcd on, cursor on, blink on
	lcd_wr_ir(0b00001111);  // mov cur. /c escr.,
	lcd_wr_ir(0b00000001);  // cursor a home.
#define _ALTERNATE_PUTCHAR_
void putchar(char c)
	lcd_wr_dr(c);
void lcd_puts(flash unsigned char *s)
	while (*s != '\0')		// repeat till end
		lcd_wr_dr(*s++);	// write data lcd change dir
interrupt [EXT_INT0] void exter()
 	PORTC = 0;
        value = 0;
        w++;
        if(w <= 1)
       		lcd_int();  // to erase initially
	value = PINC;
       	if(value == 0x0c)
     		k=0;
     		lcd_int();
     		value = 0x78;
     	 	w=0;
     		lcd_puts("enter PIN");
	value = PINC;
       	if(k <= 6)
	switch(value)
 	  case 0x0d:
	  	lcd_puts("0");
	  	break;
	  case 0x00:
	       lcd_puts("1");
	       break;
       	  case 0x01:
	  	lcd_puts("2");
	  	break;
	  case 0x02:
	  	lcd_puts("3");
	     	break;
	  case 0x04:
	  	lcd_puts("4");
	  	break;
	  case 0x05:
	  	lcd_puts("5");
	  	break;
	  case 0x06:
	  	lcd_puts("6");
	  	break;
	  case 0x08:
	  	lcd_puts("7");
	  	break;
	  case 0x09:
	  	lcd_puts("8");
	  	break;
	  case 0x0a:
	  	lcd_puts("9");
	  	break;
	 // case 0x0c:
	 // 	lcd_puts("*");
	 // 	break;
	  case 0x0e:
	  	//lcd_puts("#");
	  	break;
	k++;
	value = 0;
void main()
// 1 ====>>>> output
// 0 ====>>>> input
 // Declare your local variables here
PORTA=0x00;
DDRA=0xff;
PORTB=0x00;
DDRB=0x0b11000000;
PORTC=0x00;
DDRC=0x00;
PORTD=0x00;
DDRD=0b11111011;
//external interrups
	MCUCR = 0b00000011;   //into rising edge
	GICR  = 0x40;         //into enabled
	SREG |= 0x80;         // ints enabled
	PORTD.1 = 0;		// Relay off
	PORTD.3 = 0;		// Led red on
	PORTD.5 = 1; 		// Led green off
// initialize LCD
	delay_ms(50);
	lcd_int();
	while(PINB == 0x00);
