Atmega32-Timer0 CTC mode interrupt
Haricharan
dear friends
I have some problem with Atmega32 Timer0 application. I just wanted the timer0 to give a interrupt when a compare match occurs (CTC) mode. given below is the listing. i am using a Atmel studio 7 simulator. Everything works fine while simulating, but when match occurs between TCNT0 and OCR0, the flag OCF0 is also set in TIFR register bit 1, , and TCNT0 rolls back to 00 and starts again. but the program doesn't go to its vector address $0014. I have enabled SEI as well as CTC interrupt. ?. Kindly help thanks in advance
regards
BJ Hari charan
; soap.asm
; Author : BJ Hari; 5147d = 141Bh
;INCLUDE "M32DEF.INC"
.ORG $000
JMP START
.ORG $0002
;JMP SER_INTER
.ORG $0014
JMP MATCH
.ORG $75
START:
LDI R16,HIGH(RAMEND)
OUT SPH,R16
LDI R16,LOW(RAMEND)
OUT SPL,R16
;********Serial port intializasion***********
LDI R16,(1<<RXEN)|(1<<TXEN)
OUT UCSRB,R16
LDI R16,(1<<UCSZ1)|(1<<UCSZ0)|(1<<URSEL)
OUT UCSRC,R16
LDI R16,39
OUT UBRRL,R16
LDI R16,$00
OUT UBRRH,R16
;***not used***interrupt intialisation**********
;SBI DDRC,3 ;
;SBI PORTD,2 ; pull up resistor
;LDI R20,(1<<INT0)
;OUT GICR,R20
;SEI
;WAIT:
;RJMP WAIT
;**Trigger Ultrasonic***PORT A AS OUTPUT INTIALISATION*****
SBI DDRA,3 ; OUT PUT
SBI DDRA,4
SBI PORTA,3;LED PULSE
CALL DELAY
CALL DELAY
CALL DELAY
CBI PORTA,3;LED PULSE OFF
SBI PORTA,4
MINI_DLAY:
LDI R17,70
NOP
COUNT:
DEC R17
BRNE COUNT
NOP
CBI PORTA,4
;********Timer0 intialisation****+ Start******
LDI R16,(1<<OCIE0) ; COMPARE MATCH INTERUPT ENABLE FOR TIMER0
OUT TIMSK,R16
SEI
LDI R20,00
OUT TCNT0,R20 ;
LDI R20,$0C ; FOR MATCHING
OUT OCR0,R20
LDI R20,$09; B; 0B00100011; CTC mode; CLOCK DIV BY 64
OUT TCCR0,R20; start timer0
FIND:
RJMP FIND
;**Hex to BCD*********DIV 1000*********03ff**
LDI R23,$03
LDI R22,$db
LDI R21,$03 ;small r23 r22 03FF
LDI R20,$0E8 ;r21 r20 03E8= 1000
REPEAT1:
STS TEMPH,R23
STS TEMPL,R22
SUB R22,R20 ; remainder R23,R22
SBC R23,R21 ;
BRCC next1 ; branch on no carry
RJMP next2
next1:
INC R18
STS digit3,R18
RJMP REPEAT1
next2:
;*******Div by 100********
LDS R23,TEMPH ;get old R23,R22
LDS R22,TEMPL
LDI R21,$00 ;
LDI R20,$64 ;100
Repeat2:
STS TEMPH,R23
STS TEMPL,R22
SUB R22,R20
SBC R23,R21
BRCC next3
RJMP next4
next3: INC R18
STS digit2,R18
RJMP Repeat2
next4:
;***********Div by 10 *****
LDI R18,0
LDS R23,TEMPH ; get old values
LDS R22,TEMPL
LDI R21,0
LDI R20,10
Repeat3:
STS TEMPH,R23
STS TEMPL,R22
SUB R22,R20
SBC R23,R21 ;div by 10
BRCC next5
LDS R23,TEMPH
LDS R22,TEMPL
STS digit0,R22; REMINDER
Hang:
RJMP Hang
next5:
INC R18
STS digit1,R18
RJMP Repeat3
CHECK: ;WAIT FOR TIMER0 MATCH
RJMP CHECK; STOP Here after Compare match interrup
SER_INTER:
LDI R16,$FF
OUT DDRB,R16 ;Port B output
LDI R22,$00
OUT PORTB,R22
LDI R22,$FF
OUT PORTB,R22; toggle led
CALL DELAY
CALL DELAY
CALL DELAY
LDI R22,$00
OUT PORTB,R22;off
LDI ZH,HIGH(EXTRACT<<1)
LDI ZL,LOW(EXTRACT<<1)
AGAIN1:
LPM R20,Z
TST R20
BREQ OVER
CALL TRANSMT
INC ZL
RJMP AGAIN1
OVER:
RETI
NOP
TRANSMT:
SBIS UCSRA,UDRE
RJMP TRANSMT
OUT UDR,R20
CALL DELAY
RET
DELAY:
LDI R23,200
AGAIN:
LDI R24,255
HERE:
NOP
NOP
NOP
DEC R24
BRNE HERE
DEC R23
BRNE AGAIN
RET
.ORG $200
EXTRACT:
.DB $1F,$11," BJ HARICHARAN",$00
MATCH:
LDI R18,8
OUT TCCR0,R18 ; STOP TIMER0
RETI
Your Code spit out some errors in my STUDIO 7 IDE.
I've changed something:
; Replace with your application code
; soap.asm
.INCLUDE "M32DEF.INC"
.org 0x000                    ; kommt ganz an den Anfang des Speichers
jmp START           ; Interruptvektoren überspringen
                              ; und zum Hauptprogramm
reti; jmp EXT_INT0 ; IRQ0 Handler
reti; jmp EXT_INT1 ; IRQ1 Handler
reti; jmp EXT_INT2 ; IRQ2 Handler
reti; jmp TIM2_COMP ; Timer2 Compare Handler
reti; jmp TIM2_OVF ; Timer2 Overflow Handler
reti; jmp TIM1_CAPT ; Timer1 Capture Handler
reti; jmp TIM1_COMPA ; Timer1 CompareA Handler
reti; jmp TIM1_COMPB ; Timer1 CompareB Handler
reti;$012 jmp TIM1_OVF ; Timer1 Overflow Handler
jmp MATCH ; Timer0 Compare Handler
reti; jmp TIM0_OVF ; Timer0 Overflow Handler
reti; jmp SPI_STC ; SPI Transfer Complete Handler
reti; jmp USART_RXC ; USART RX Complete Handler
reti; jmp USART_UDRE ; UDR Empty Handler
reti; jmp USART_TXC ; USART TX Complete Handler
reti; jmp ADC ; ADC Conversion Complete Handler
reti; jmp EE_RDY ; EEPROM Ready Handler
reti; jmp ANA_COMP ; Analog Comparator Handler
reti; jmp TWI ; Two-wire Serial Interface Handler
reti; jmp SPM_RDY ; Store Program Memory Ready Handler
;.ORG $000
;JMP START
;.ORG $0002
;JMP SER_INTER
;.ORG $0014
;JMP MATCH
.ORG $75
START:
OUT SPH,R16
LDI R16,LOW(RAMEND)
OUT SPL,R16
OUT UCSRB,R16
OUT UCSRC,R16
LDI R16,39
OUT UBRRL,R16
LDI R16,$00
OUT UBRRH,R16
;SBI DDRC,3 ;
;LDI R20,(1<<INT0)
;OUT GICR,R20
;SEI
;WAIT:
;RJMP WAIT
SBI DDRA,4
CALL DELAY
CALL DELAY
CALL DELAY
SBI PORTA,4
MINI_DLAY:
LDI R17,70
NOP
COUNT:
DEC R17
BRNE COUNT
NOP
CBI PORTA,4
OUT TIMSK,R16
SEI
LDI R20,00
OUT TCNT0,R20 ;
OUT OCR0,R20
FIND:
RJMP FIND
LDI R23,$03
LDI R22,$db
REPEAT1:
STS TEMPH,R23
STS TEMPL,R22
SBC R23,R21 ;
RJMP next2
next1:
INC R18
STS digit3,R18
RJMP REPEAT1
next2:
LDS R22,TEMPL
LDI R21,$00 ;
LDI R20,$64 ;100
Repeat2:
STS TEMPH,R23
STS TEMPL,R22
SUB R22,R20
SBC R23,R21
BRCC next3
RJMP next4
next3: INC R18
STS digit2,R18
RJMP Repeat2
next4:
LDI R18,0
LDS R22,TEMPL
LDI R21,0
LDI R20,10
Repeat3:
STS TEMPH,R23
STS TEMPL,R22
SUB R22,R20
BRCC next5
LDS R23,TEMPH
LDS R22,TEMPL
Hang:
RJMP Hang
next5:
INC R18
STS digit1,R18
RJMP Repeat3
SER_INTER:
LDI R16,$FF
LDI R22,$00
OUT PORTB,R22
LDI R22,$FF
CALL DELAY
CALL DELAY
CALL DELAY
LDI R22,$00
OUT PORTB,R22;off
AGAIN1:
LPM R20,Z
TST R20
BREQ OVER
CALL TRANSMT
INC ZL
RJMP AGAIN1
OVER:
RETI
NOP
TRANSMT:
SBIS UCSRA,UDRE
RJMP TRANSMT
OUT UDR,R20
CALL DELAY
RET
DELAY:
LDI R23,200
AGAIN:
LDI R24,255
HERE:
NOP
NOP
NOP
DEC R24
BRNE HERE
DEC R23
BRNE AGAIN
RET
.cseg
;.ORG $200
EXTRACT:
MATCH:
LDI R18,8
RETI
.dseg
TEMPH: .BYTE 1
TEMPL: .BYTE 1
digit0: .BYTE 1
digit1: .BYTE 1
digit2: .BYTE 1
digit3: .BYTE 1
In my STUDIO 7 the Timer 0 Interrupt Vector wouldn't be active.
Because all the Registers are proper filled, in real Chip it should work.
I guess there is a BUG in debugging Software. Try it out!
EDIT!
The Command:
don't divide by 64 it divides by 1!
