[SOLVED] ATMEGA644 question/issue?
I'm a bit familiar with AVR micro's, but I'm having a problem with the basic LED blink test with this particular controller. Every time I try to just turn an LED on or off via GPIO port, the LED blinks very quickly. Uc is hooked up with basic ISP, internal osc at 8mhz, no divider, jtag disabled, on board debugging disabled, 5V supply I know is good. I'm not telling it to blink, even trying to pwm a led it does the same blink, code is:
#include <avr/io.h>
int main(void)
DDRB |= (1<<0);
PORTB |= (1<<0);
for(;
Very simple, should just turn PORTB.0 to high and leave it. This works on Attiny2313 and atmega168's as expected, but on the 644 it causes a constant blink.
I must have missed some single line in the datasheet or something, but I've looked a few times for an answer. Google is also not turning up this question so I'm assuming I'm making a VERY noob mistake. Just want to solid on a port, any suggestions?
Thanks in advance!
Robert
#include <avr/io.h>
int main(void)
DDRB |= (1<<0);
PORTB |= (1<<0);
for(;
Thanks in advance!
Robert
