DigiTan
I've been working on a security device program all afternoon. The program so far was supposted to be simple: use the hardware timer to blink an LED while the device is calibrating.
This worked perfectly until just a few hours ago, when the program just "fell apart" and appearantly does nothing. First, the LED refused to blink at all, even though single-steping through the code revealed software had no errors--yet the chip was running the timer interrupt at all.
Next, it stayed "frozen" unless I uploaded from the Simulator instead of the HEX file. Doing this made it work perfectly--but after doing this three more times, AVR Studio reads: WARNING: FLASH contents differs from file.. FAILED! The strange part is, this chip is brand new, and the flash only has maybe 30-40 writes to it. Also, strange it started "freezing" before any FLASH problems were detected.
I've re-checked the programming 20 times, simulated, and commented out all but the most basic functions. Obviously, the chip is defective, but I wanted to run the code by you guys just in case.
Also when loading the AVR programmer window, it said it needed a firmware upgrade, but I cancelled this. This would've caused suspicion, but the ATtiny12 programs have gone perfectly until just this evening.
* I have AVR Studio v4.11 and recently upgraded from build 171 to build 401--and I'm using the built-in simulator for debugging. I'm programming with STK500 (firmware v1.0A), and it's suggesting I upgrade to v2.00. Will the upgrade make any difference? The ATtiny12 is using its internal 1.2MHz clock.
;- Register Aliases -----
.def quarters = R1 ; Quarter-second counter (int-driven)
.def blink_rate = R2 ; LED flash rate ; 0 = off
; 1 = ~1/2 sec
.def prev_sensors = R3 ; Previous sensor state
.def delay_ovf = R4 ; Used by 1/4sec delay routine
;.def = R16 ; General-purpose register by tradition
.def loop = R17 ; Loop/increment counter by tradition
.def addr_a = R18 ; 8-bit Address-holder by tradition
.def addr_b = R19 ; 8-bit Address-holder by tradition
.def i_temp = R20 ; Interrupt's temp register
.def instability = R21 ; Sensor stability failures
.def loop2 = R22 ; Secondary loop counter
;# Flash Memory #
.cseg ; (Begin) Code Segment
.org 0x00 ; Start address
rjmp main ; Reset Vector
; Interrupt Vectors #
; Tiny12 #
RETI ; IRQ0 Handler
RETI ; Pin Change Handler
rjmp tc0i ; Timer0 overflow
RETI ; EEPROM Ready Handler
RETI ; Analog Comparitor Handler
main:
;---Port Direction Setup-
ldi R16,0b00011000 ; Create input/output states
out DDRB,R16 ; All ports used for I/O roles
;---Port Initialization--
ldi R16,0b00011111 ; Pull-up resistors on (PB.5 not equipped)
out PORTB,R16 ; LED and Alarm on breifly
;---Analog Comparitor Disable
ldi R16,0b10000000 ; Sent config: [7] Comparitor turn-off
out ACSR,R16 ; [3] Comparitor interrupt disabled
;---Watchdog Timer Disable
ldi R16,0b00010000 ; Sent config: [4] Watchdog turn-off
out WDTCR,R16 ; [3] Watchdog disable
;---Timer 0 Interrupt----
ldi R16,0b00000101 ; Prescale: 1.2MHz / 1024
out TCCR0,R16 ; Interval: 853us Overflows: 0.218s
STANDBY:
;---External Interrupt Setup
ldi R16,0b01000000 ; Sent config: [6] IRQ0 Enabled
; out GIMSK,R16 ; [5] Pin-change interrupt disabled
SEI ; Global Interrupt Enable
;---Power-down Enable/IRQ Mode
; cbi PORTB,3 ; Alarm latch off
; cbi PORTB,4 ; LED latch off
; ldi R16,0b00110010 ; Sent config: [5] Sleep Enabled
; out MCUCR,R16 ; [4] Sleep mode [0,1] falling edge trigger
;---Micro-power state----
; sleep ; Awaken to IRQ0 routine
;---Sleep/IRQ0 Disable---
clr R16 ; R16 = 0
out MCUCR,R16 ; Sent: [5] Sleep Disabled
out GIMSK,R16 ; Sent: [6] IRQ0 Disabled
;---Check IR Data Port
ARMED:
;---Timer Interrupt Enable
ldi R16,0b00000010 ; Timer overflow interrupt enable bit set
out TIMSK,R16 ;
;---Stabilization-Countdown
ldi R16,0b00000010 ; Change LED blink rate
mov blink_rate,R16 ; New blink rate = ~1.2 Hz
debug:
rjmp debug
tc0i: ; [Nominal int rate = 4.57Hz]
inc quarters ; Update counter for main loop codes
mov i_temp,quarters ; Store "timer" to temporary register
and i_temp,blink_rate; Mask to determine LED blink rate
breq led_off ; If
led_on:
sbi PORTB,4 ; LED on
rjmp led_done
led_off:
cbi PORTB,4 ; LED off
led_done:
reti
