ThermalRunaway
Hi everyone. I came across a concept today which I was unfamiliar with so I've been trying to learn more about it. My confusion is based around screening techniques for Audio Leads.
I have been fault-finding some military communications equipment at work, and I found that a number of the units had failed test due to slightly low sidetone levels. I decided to retest the units to observe the failure for myself, and I found that actually the units would pass provided that you allowed them to cycle on the sidetone test for a few times. I also found that the sidetone measurement, taken in Decibels, would fluctuate by quite a high margain so that a pass or fail depended on how the audio analyser caught the measurement. I put passed units back on the test and found that they exhibited the same symptoms.
I decided that there must be some form of problem with the test gear or interconnecting leads to be causing that kind of fluctuation in sidetone measurement, so I set about tracing the problem. I came across a 5-pin comms leads which I felt had faulty cable screening. The cable itself was screened, but having done a continuity test between the shields of the two connectors (one at each end of the lead) I found that the screen was o/c.
I happened to mention this to one of my work colleagues, and he said that the lead probably was not faulty and that it could quite well have been designed that way. He said that quite often, in audio systems, only one end of the lead has the screen connected because this helps to avoid ground loops.
Not being one to take anyone's word on anything, I decided to try and find out more for myself but I've done a bit of internet searching and I haven't turned up much of anything.
Is anyone else familiar with this?
Brian
Brian
