Improve how?Now, Is there any software to improve the quality of an audio too?
Yes, but you won't like my answer. Any decent audio editing software have some low pass filter function. Filtering away any frequensis above, say 2kHZ will probably remove any audible noise that you get from lossy sound compression formats. But it will also parts of the sound that you don't want to remove.Now, Is there any software to improve the quality of an audio too?
An LPF is not effective for noise-reduction: it doesn't remove low frequency noise and it destroys the signal you want to retain. As stated above, some audio editor software packages contain a noise-reduction function which uses a filter modeled on the background noise of the recording.Yes, but you won't like my answer. Any decent audio editing software have some low pass filter function. Filtering away any frequensis above, say 2kHZ will probably remove any audible noise that you get from lossy sound compression formats. But it will also parts of the sound that you don't want to remove.
Exept from that, the answer is no.
