danrogers
Hi all, I have just thought of something that would be usefull for me to have and a cool project.
I have a couple of nitro RC cars that need to have 1.5v applied to a glow plug while you crank the engine over to start it. Once started you can remove power to the plug.
Most people use a rechargeable glow starter which is ok but some hassle really.
i want to make something that will take 1.5v from the onboard reciever battery (1600mah 6v) for a set amount of time, maybe about 2-30 seconds when you press a push to make switch. An led would also be helpfull you you can see when the power is on.
How would I work out the drain that would place on the battery?
And could you help me select some components, I know I will need a 1.5v regulator but not sure which and how would it be easiest to design a timer circuit?
I would like to keep it as small as possible to fit inside the receiver box![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
