I'm sorry but I don't see a transformer in the circuit. Are you sure your group posted the correct circuit?
That's an AVR micro controller, and the code you posted is HEX code converted to ASM, from the looks of it the code came from a C compiler, I don't memorize AVR I/O address so I can't interpret the code unless it was written in ASM nativly, or I spent two hours looking up all the register address's. Why are you reverse engineering someone elses hex code?
It's not an AVR, it's an 8051. And it won't work because the micro can't source enough current to drive the transistors to drive the relay or light the 7-segments. You need to forget that circuit altogether.
actually i hav posted to that person. but he does not reply fast...and i need help urgently... can u tell me what d problem might be if the relay does not remain in stable conditon that is continuously switches from NO-NC...i hav built power supply for it...
Why is it urgent? Boogeyman under the bed?
it is urgent cause i hav 2 submit d project within a week........
