Thunderchild
I'm going to set up a small solar power system (40 W of solar panel and a car battery with a 150 W inverter). now obviously I won't have enough power for non stop power. I'm planning on using the solar system to run the house lighting system only. What I thought of doing was setting it up so that the solar system supplied the power to the lights whilst the battery had power and once that was used it will automatically revert back to the grid.
Now bearing in mind that the inverter will not be located by the mains supply I need to devise a way of having automatic changeover from battery to mains, even if this means that once the battery is dead it stays on the mains until I "reboot" the solar system into supplying power
