Hi
I have occasion to work on aviation headsets occasionally and rather than buy an aircraft intercom to just use on the workbench, I am thinking there might be an easy solution with parts on my bench. The mics are called amplified electret.
Spec sheet of a typical set is here https://www.davidclarkcompany.com/files/literature/10-13.4.pdf
I have an old set of computer speakers that I thought might be just the ticket but connecting them together (headset mic to speaker input) did nothing so I am thinking that I need a small preamp. I don't understand the DC voltage or how to incorporate it in my test amp, that is mentioned in the literature (Mic DC Supply V. )
Would an LM386 do the job? https://www.ti.com/lit/ds/symlink/lm386.pdf
Or maybe there is an easier way. Since the speakers are brought out on one plug and the mic on the other, I could probably connect, through an amp, the mic to the same headset speakers. The most common fault is broke wires but occasionally, a bad mic or speaker or some have volume controls. By having them as one complete system, I would be talking to myself while wearing them. In the past, I might hold one set to talk into the mic and wear the other set.
For straight audio, I was planning on simply connecting an audio source but the speaker impedance is 150 ohms and most audio outputs are designed for 8, no?
Any suggestions?
Shawn
Any suggestions?
Shawn
