I found this TV-B-Gone project I want to build, but the source is in C, an uses the GCC compiler. https://www.ladyada.net/make/tvbgone/download.html
I don't know much about C, or how to use the compiler, but tried a few times to get it to build the hex file, but just get errors. So, basically have no idea what I'm doing. There are four files in the source ZIP.
So far, I've only programmed in assembly, so haven't had to learn about C or BASIC compilers, so I need a quick walk through the process of making a hex file from C. Or if you are feeling generous, just compile the hex for me (although I should learn this stuff sometime).
I'll have to order the Tiny85 (needs the 8k flash), and an 8 mhz crystal, so have about two weeks to get the program ready to burn. Also going to do my own PCB. Their's is in Eagle and two sided, also seems a little larger than needed. I want it a little smaller and descreet. I think the ISP header was the reason they went with a 2-sided board, it's an 8 pin chip, so a socket will be fine. The use 4 IR LEDs, but 2x60 degree should work just as well.
