dreamproject
hi all,
nice to be back . haven't posted in a while . !!. How are you all ?
I am using an LM629 motioncontrol IC. It needs a 6 Mhz. sytem clock . The LM629 is being programmed by a 16F877 pic . Can i use the clock out from the pic to provide system clock to the lm629 or do i have to provide a seperate clock . If this to be done with a 6 Mhz. crytal , it has two pins but the system clock needs to be input on only one pin on the lm629. Can i use a 555 for this . I heard that the 555 is unstable at such high speeds.
Thanks in advance
Thanks in advance
