Someone Electro
Dose any one know BASIC compilers for PIC16F88
Someone Electro said:yep i yust found that one.And i think its realy good.
the only limitaon is an 2K hex maximum (il find a way to fool it IF i will ever need more)
mastertech said:Picaxe is a small micro that doesnt need compiler or programmer to
be programmed, it comes with a cable and software and can be programmed in basic in minutes, you simply download and your program runs instantly ,if you are creative, this device could
be remarkable at the right hands
Someone Electro said:I think i will stick whith the original PIC (i alredy orderd PIC16F88 for simple stuff an PIC18F252 for complicated stuf)
dose anybody know a programing software to work whith the programer below (for PIC16F88 and PIC18F252 )
Someone Electro said:found another PIC programer:
this one fucons on an serial prort and dosent need an external power suply
https://www.rentron.com/Myke4.htm
an nother paralel port one
but this one is i think the best:
I like ICSP
Someone Electro said:all i want from an programer is:
-writng in memory
-reeding from memory
-erasing memory
-ICSP (I dont want to keep sticking the PIC in and out of the breadbord to do only a minor ajustment in the code)
Someone Electro said:I reed that you can esaly berak pins on the PIC by pluging it in an out (i know how hard an contact can jam in the breadbord)
