I have a question about integrated circuits. I have an integrated circuit and its document sheet explains that it is active on Logic Low at Enable pin. So, if I want to make int.cir. active, should I connect Enable pin to ground? I wonder whether logic low is equal to ground.
If I connect Enable pin to ground, will integrated circuit be active?
Thank you.
Thank you.
