Hello all,
the idea is this: to have increased bass from the tone control of a passive bass guitar.
I would like to enhance the bass without having an additional potentiometer, as there is physically, no space to do so. It is also the case that the fitted potentiometers are miniature so as to comfortably fit into the available cavity, thereby, negating the use of standard sized pots. The use of a stacked dual concentric pot is also beyond the bounds of feasibility, as I would have to modify the existing circuit in a way that I have not a clue how to do!
The problems I have are limited electronic knowledge and being unable to find among the array of websites, a simple enough circuit that I could utilise and install. I would also like to know if such a circuit is possible to achieve without using transistors, op-amps and inductors.
Do not be fooled by the apparent competence I display, I really am quite ignorant, but it is owed to weeks of research that I can communicate to this level.
Could somone pease help me by providing a detailed schematic and any information that may seem relevant.
Thank you.
Thank you.
