battery backup
Hello Guys,
I need a battery backup circuit for a 3.3V power supply I am using.
I found this one on the internet but I am concerned that there might be a safety issue with the lithium battery (explosion hazzard?)
Any advice?
I don't need the circuit to charge the battery, I prefer to use a lithium battery because I have many here.
Hello Guys,
Any advice?
Which type of lithium battery do you have?
https://en.wikipedia.org/wiki/Lithium_battery
I got the circuit to work (without the resistor)
it works perfectly. When power is removed, the battery power is being used.
I am just worried about any possible danger to the battery popping.
(I do not want a fire in my house!)
working circuit
Here is the working circuit. For battery, I used two AA batteries (3V total).
The Schottky diodes were ones I had. (SD103BDICT)
I used this for a MP3 player/voice recorder setup that does not use a battery (3VDC wal wart).
When the power goes out, the configuration is lost in the player. This is the reason for the battery backup.
It works perfectly now thanks to the information provided by ericgibbs.
Thank you
