G'day all, probably an easy one...but not for me ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I have a battery charger (Sunpak qbc-5) which has died.
One of the components is shot, and I can't identify whats left of it...
It has the form of a resistor (small ones) appears to have been made of glass, whitish in the middle and brown at both ends where the leads exit.
I can just make out what looks like 'EML F 120v Ψ' but nothing else (phase shift component??).
It was piggybacked (embedded) on top of a larger white block ceramic resitor if that helps at all, connected to the same spot on the PCB at one, and at a different spot on the other...
Can anybody help identify what that was so I can fix it?
Thanks in advance.
PS voltage in 240 (charger is selectable 120/240v) LED lights up ok so circuit gets some power after the transformer, but no output at low voltage plug end.
Thanks in advance.
