battery for ESP32 Developer board
Erhy
Hello!
I want use a ESP32 Developer board fo use in field.
Have you a tip for me, to choose a little device for charge and work without replace the battery?
Thank You
Erhy
You don't mention any requirements - battery life etc.
First thought - this comes to mind.
Thank you!
Your suggestion is an ESP board with built-in battery holder an charger.
I would prefer a separate box for the 5 Volt.
In which case you need to give much more information about your exact requirements.
But as an ESP32 is 3.3V (after it's regulator) a Li-Ion 18650 or pack makes a sensible option.
now I changed my thoughts.
In my project is also a motor driver board connected to a 7.4V 6000mAh LiPo battery.
Now my question changed:
What is a safe connection from the LiPo battery to the 5 Volt pin?
Is a diode and than a tantal condensator enough to lessen high frequency disturbances ?
Bother the little bit higher voltage the USB source of the PC?
