flow T narg
This is a nice projects for a kids small pool, the overall unit automatically pumps water through a metallic radiator, which easily sets on the gas grill. heating a small pool on only one $8 cylinder of propane. (solar is another idea)
Any one have a plan for a solid-state circuit that can generate a spark for lighting a gas grill / pool heater? The gap is about 4 mm wide and should produce 15-20 kv. I have a 6 volt battery for operations.
The remainder of the circuit will sense the thermostat, will open the gas valve , run a timer complete the above spark gap circuit for a few seconds. when temperature is met: shut gas off when temp is reached and circulating pump off after 5 min .
