p.gholap93
I want to do battery voltage indicator using LED bar graph and LM 3914. When battery voltage falls below 10V all the LEDs in bar graph shopuld be off. And when battery voltage is full i.e. 12V all the LEDs should be on. But the problem is if I apply 12V directly to SIG pin of LM3914 then the IC gets heated. Should I connect current limiting resistors externally to the display?
