baud rate
aamirkhan
hi
i am trying to write a program to send data to PC through air using LEDs and
photodiodes . i am using 4800 baud rate to comunicate .thus for approx 208microsec the led should toggle to send one bit. i have wriiten a program to toggle the led ,wait for 208 microsec and then toggle again.
BUT THATS NOT WORKING
data is displayed but not the one i try to send
Can anybody tell me how to calcute the delay time between two toggles for 4800 baud rate
i am not using UART its already occupied .I have to built another using program.
If I understand correctly, you want to write the program for a 'software' UART.
Look at Nigels tutorials link, bottom of this post.:)
Use a wire connection first to debug the 232, and once you have it working use the LED, so that you can address one problem at a time. Never tried 232 in software so can't help you on that.
edit to add: If you use the LED/photo setup on your existing uart connection, does it work?
