Beginner question.
I'm using veroboard: the parallel plating traces are a little less than .100" wide running the entire length of the board. As far as I can tell, this manufacturer uses 35 µm, or 1 oz/ft^2 of copper. I'd like to run 4A through the traces, pretty continuously for 6-8 hours a day.
The calculator at The CircuitCalculator.com Blog PCB Trace Width Calculator tells me that such a trace will carry 2A. With a 10°C rise in a "potted" circuit. I guess I'm potted, I'm using a project enclosure.
But then, https://www.electro-tech-online.com/custompdfs/2009/02/slup230.pdf says, "Consider a 0.1-inch wide, 1-ounce trace. For 10ºC rise, the conductor current carrying capacity is 4 A." They say this is conservative.
I'm trying to avoid bubble and smoke. Which source is accurate? Could I solder copper wire parallel to (that is, on top of) the traces to Vin and Gnd? Should I really add a relay to the circuit?
Could someone with actual experience of 1 oz/ft^2 copper traces please tell me if it handles 4 amps of current?
Thanks very much for your help.
Beginner question.
