Musicmanager
I have a Bench DMM which is badged as a Mc Voice M980T which I'm reliably informed is actually a Mastech M9803R.
I used it recently to set the voltage across a timing resistor but then at a later moment I checked that voltage with my Fluke DMM which demonstrated that the Mastech calibration is approx. 800 mV's down and needs calibrating. I know the Fluke is accurate because I had it professionally calibrated quite recently.
I watched the calibration of the Fluke .. .. he injected an accurate voltage of 250 mV's and then adjusted the one and only preset until the display matched.
Foolishly I concluded calibrating the Mastech by the same method would be a simple process, so I opened it up, adjusted my bench PSU until the Fluke measured exactly 250 mV's, grabbed my preset adjusting tool and then found 3 presets inside the Mastech ! Which is which is which ?
Does anybody have the correct calibration manual for the Mastech or the expertise to solve the puzzle please.
I did email Mastech in China and they sent me a single page document, but in Chinese or Mandarin or the like and Google Translate seems to think it might be a recipe for Chocolate Muffins !
MM
MM
