I am trying to generate three sine waves 120 degrees out of phase with the option of changing the volts to hz ratio in a linear way i.e. when the amplitude of the sine waves change, the frequency must also change once a volt/hz ratio has been set.
Whats the best way to generate the sine waves?
These sine waves can then be used to create a pwm pattern when compared with a triangle wave.
