Binary clock/counter with interrupt, 16F690
Emil09
So I've got some code where the clock part functions but the external interrupt doesn't. The microcontroller counts up in binary on 4 LCDs, and should stop counting on the interrupt which comes on RA5. Unfortunately, nothing happens when I ground RA5. Thoughts?
#include <p16F690.inc>
__config (_INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _BOR_OFF & _IESO_OFF & _FCMEN_OFF)
cblock 0x20
Display
W_Save
STATUS_Save
endc
org 0
goto init
ISR:
movwf W_Save
movf STATUS,w
movwf STATUS_Save
btfss PORTA,5 ;test bit, skip if set
goto ExitISR
btfsc PORTA,5
goto Start_Stop
clrf Display
goto ExitISR
Start_Stop:
clrf RABIF ;clear flag
bcf OPTION_REG,PSA ;prescaler is assigned to the Timer0 module
ExitISR:
movf STATUS_Save,w
movwf STATUS
swapf W_Save,f
swapf W_Save,w
retfie
init
banksel OSCCON ;select oscillator control
bcf OSCCON,6 ;set postscaler to 250 kHz
bsf STATUS,RP0
movlw b'00000111' ; configure Timer0. Sourced from the Processor clock;
movwf OPTION_REG ; Maximum Prescaler
clrf TRISC ; Make PortC all output
clrf Display
bcf STATUS,RP0
bsf INTCON,7 ;global interrupt enabled
banksel PORTA
bsf TRISA,5
bsf IOCA,5 ;interrupt on change enabled
;btfss PORTA,5 ;test bit, skip if set
ForeverLoop:
btfss INTCON,T0IF ; wait here until Timer0 rolls over
goto ForeverLoop
bcf INTCON,T0IF ; flag must be cleared in software
incf Display,f ; increment display variable
movf Display,w ; send to the LEDs
movwf PORTC
goto ForeverLoop
end
  • monday_bin_clk..asm
First thing I would do is change the ISR to only set a port B pin to light an LED. Then you know for sure if the ISR runs or not.
hi emil,
Look at this edited code.
The problem was in the Init subr.
Setting PORT,5 hi/lo now generates an interrupt, also stop/start
	list  p=16F690         ; list directive to define processor
	errorlevel  -302 , -207             ; suppress message 302 from list file
	cblock	0x20
	Display
	W_Save
	STATUS_Save
	endc
	org	0
	goto	init
	org 0x0004
ISR:
	movwf	W_Save
	movf	STATUS,w
	movwf	STATUS_Save
	goto	ExitISR
	btfsc	PORTA,5
	goto	Start_Stop
	clrf	Display
	goto	ExitISR
Start_Stop:
	bcf	INTCON,RABIF		;clear flag
ExitISR:
	movf	STATUS_Save,w
	movwf	STATUS
	swapf	W_Save,f
	swapf	W_Save,w
	retfie
init
	bsf	STATUS,RP0
	movlw	b'00000000';111'	; configure Timer0. Sourced from the Processor clock;
	clrf	Display
	bcf	STATUS,RP0
	bsf 	INTCON,RABIE
	bsf 	STATUS,RP1
	clrf 	ANSEL
	bcf 	STATUS,RP0
	bcf	STATUS,RP1
	bsf	TRISA,5
	bsf	STATUS,RP0
	bcf 	STATUS,RP1
	bcf 	STATUS,RP0
	bcf	STATUS,RP1
ForeverLoop:
	goto	ForeverLoop
	movwf	PORTC
	goto	ForeverLoop
	end
Fantastic! Thanks a lot Mr. Gibbs! :)
hi emil,
Note: that the TMR0 prescaler has been shortened to suit an Oshonsoft simulation.
Reload the TIMR0 with your original value.
bsf	STATUS,RP0
	movlw	b'00000[COLOR="RoyalBlue"]000';111[/COLOR]'	; configure Timer0. Sourced from the Processor clock;
