ChildOfVision
Hi to everyone!
Long story short: In last dozen of attempts![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
(I'm using toner-transfer method) everything seems fine until I remove toner after apparently successful etching - I got black stuborn dots and marks all over the copper (regardless whether it is a larger copper filling or trace/pad) - please see picture. It is, as I know, black copper-oxide - I can't remove it by any means! It is not "standard" pitting, as someone could conclude from picture - copper is not etched totally in "dot-areas" - it looks like somebody imprinted black particles into healthy copper surface! I tried different plates (from different batch), every sort of papers (including TRF-Green!) but with no avail. Note: after laminating (toner sticks to PCB very well), if I remove toner (without etching) I just get clean copper surface!
I'm using muriatic acid (20%) and hydrogen-peroxide (12%) without adding water.
Any opinion appreciated! Especially if somebody had the same problem!
TIA!
TIA!
