Are you sure it is 1000Kv?
Is it P.M.?
Max.
ok, because i was shorting the 3 wire of it it was not rotating due to which i sure it has Permanent magnet in it.You need 1000 RPM to get 1V.
It is an impeller ducted fan and it is inside using the same air intake and exhaust as the jet turbine engine in a real jet airplane. The impeller has 5 blades and is 28mm in diameter. The powerful brushless motor is tiny.Where is the propeller motor in plane?
Hello,
I have A2212-13 1000KV BLDC motor of Mystery company.
it is not generating a ack EMF which i have seen in PMDC motor.
I have connected the multi meter in measuring AC and DC .Incidentally the motor will generate 3ph AC not DC if that is what you were attempting to measure.
There must be something really subtle there. Can you explain it a little more?in Real jet plane what is the enjine will be .
I mean how it work?There must be something really subtle there. Can you explain it a little more?
How they mix fuel with blades ?A jet engine is a jet turbine that compresses incoming air with some impellers, mixes it with fuel and it burns creating thrust. For more thrust they shoot more fuel into the output which is called an afterburner and you can see the fire coming out.
