Bluetooth Keyboard Not Connecting
Pavi98
Hello all ,
I got an old bluetooth keyboard that requires 1.5V AA battery supply. Once the battery is inserted, a red light indicator turns on and suddenly turns off. There is no any on/off switch in the keyboard. Also, in my laptop, a bluetooth keyboard is not showing. How can I turn on this keyboard? Is something wrong with the circuit of the keyboard? The only circuit available in the keyboard is attached below.
Thank you
It may have stored connection data for a previous device, so not be doing anything if it does not detect that.
Try holding the power button in for anything from 10 to 30 seconds & see if the light starts flashing - that probably means it's in "connect" mode and should be detectable by your laptop.
Or try keeping the button pressed while and after fitting the battery; that's another reset method some devices use.
Or method 2, wait a minute then try method 1, or method 1 twice in a row..
