Mike - K8LH
I'm struggling trying to get a cycle accurate fixed/constant delay macro running in BoostC. Here's what I'm trying to duplicate;
And here's how I'd like to be able to use it in a BoostC program;
I would just code the delays as in-line assembly but the BoostC compiler doesn't support assembler expression evaluation such as movlw (8*tstep)/4-1-2.
I appreciate any help guys.
Regards, Mike
clock equ 8 ; 4, 8, 12, 16, 20 MHz, etc.
usecs equ clock/4 ; cycles per usec multiplier
tStep equ 1*usecs ; cycles per BAM step (1T)
; in-line fixed delay macro, 0..1027 cycles, 14 bit core
inDlyCy macro delay ; generates 0 to 6 instructions
local loop
if delay > 3
movlw delay/4-1 ;
loop addlw -1 ; borrow? (4 cycle loop)
bc loop ; no, branch, else, fall thru'
endif
if delay%4 >= 2
goto $+1 ; delay%4 == 2 or delay%4 == 3
endif
if delay%4 & 1
nop ; delay%4 == 1 or delay%4 == 3
endif
endm
* 1-usec BAM step size (1T) *
void interrupt()
{ pir1.TMR2IF = 0; // clear Timer 2 interrupt flag
porta = colsel; // select new column
portb = bdat[0]; // 2^0 (1T) data
inDlyCy(1*tstep-2); // 2^0 (1T) delay
portb = bdat[1]; // 2^1 (2T) data
inDlyCy(2*tstep-2); // 2^1 (2T) delay
portb = bdat[2]; // 2^2 (4T) data
inDlyCy(4*tstep-2); // 2^2 (4T) delay
portb = bdat[3]; // 2^3 (8T) data
inDlyCy(8*tstep-2); // 2^3 (8T) delay
Regards, Mike
