hi
i want to design an infrared communication between two modules. the frequency of communication doesn't need to be very high... the range on the other hand i need it to be of the order of at least 2 meters preferably more...
the communication is always in one way, ie i only have one receiver and one transmitter. the transmitter can only be driven with a supply of 3v.. whilst the receiver has up to 5V...
just to have a general idea of m design it is like the infrared communication in car alarms...
now, i bought a bpw41n which is said to be used for TV sets, and an infrared led (i have two type one with the blue package and another with the transparent package)..
receiver: using a 7805 i fed the Bpw41n using a 1.2Mega ohm (i also tried the 3Mohm and the 620k resistors, the difference is that the voltage on the bpw41n when in the dark condition is less as the resistance increases) voltage on the Bpw41n is read using a digital multimeter...
transmitter: using a 3v button battery i switched on the IR led using a 75 ohm resistor(i reduced it up to 9.1 ohms also with similar results for each value of resistance, the battrey voltage decreased to1.5V when i connected the resistor and led setup to it ) i also tried the same procedure using a 6V battery, and again the voltage decreased to 4V as i connected the transmitter setup(for this case i also varied the resistance from 220ohms down to 9.1ohms)...
every time the results were the same, the communication can only be sustained to up to 2 inches maximum....
each procedure was tried using another Bpw41n ic and IR led with no difference at all ...
this is certainly not a good result.. any ideas how to properly use the Bpw41n please?
thanks a lot
![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
thanks a lot
