some1 tell me what makes a tv real bright cant ajust down seem if u try the pic trys to get a little better + got high voltage lines cant turn flyback down bottom out
i check the voltages it said check g2 to e2 it called for 210 v i got 206 i thought that was ok im kinda new at this tho i will insert picture of neck board i checked the g2 well i think i did lol it read 190v
I check all resistors I don't think I know how to check the g3
im little scared that i would burn my fluke meter up explain how to
if you dont care buddy burnd his meter up I found a bad resistor
On neck board change it still the same funny thing is
That when I turn the fly back down quick the picture
Goes right for a second does that sound like a fb ?
If your fluke is a class 3 then it should be fine, assuming its a 'fluke', that name and 'avo' seem to be used like the term 'hoover' does and apply to any old meter.
The fb doesnt usually cause a bright picture, and if the cathodes and grids are about the right voltage which you said they are earlier up, unless theres a bad connection to the picture tube base then maybe the tube has an internal short, especially if the machines been upended or led down.
I remember the days of the 'bulb bopper', those things raised a few eyelids, for dealing with a short however sometimes a cap charged to ht can improve things, but its fairly involved and a bit risky.
i think the tube is fine i tryed another 1 same kind same results dont think if would help to deguass it these r old machines hate to spend alot
they want sale for $100 r 200 anymore ideals?
